Programmieren - alles kontrollieren 4.947 Themen, 20.745 Beiträge
Problem: es meldt immer einen Fehler beim Kompilieren ,
mac4dac / 8 Antworten / Baumansicht Nickles
Hi leute,
ich bin scho wider. Egal was ich mache es meldt immer einen Fehler beim Compiler.Ich bitte um Hilfe,..
ciao
mac4dac
Program LED_Ausgabe;
Uses crt, DOS;
VAR stelle,wert:byte;
    choice: char;
procedure writeport(wert:byte ,stelle:byte);
begin
  IF (stelle>=0) AND (stelle<=5)
  THEN
  begin
    stelle1:=stelle shl 1;
    port[$37A]:=stelle1;
    delay(1);
    port[$378]:=wert;
    port[$37A]:=stelle1+1;
  end;
end;
function crewert(w:char):byte;
begin
  IF w='0' THEN crewert:=$C0;
  IF w='1' THEN crewert:=$F9;
  IF w='2' THEN crewert:=$A4;
  IF w='3' THEN crewert:=$B0;
  IF w='4' THEN crewert:=$99;
  IF w='5' THEN crewert:=$92;
  IF w='6' THEN crewert:=$82;
  IF w='7' THEN crewert:=$F8;
  IF w='8' THEN crewert:=$80;
  IF w='9' THEN crewert:=$90;
  IF w='H' THEN crewert:=$89;
  IF w='E' THEN crewert:=$86;
  IF w='L' THEN crewert:=$C7;
  IF w='O' THEN crewert:=$C0;
  IF w=' ' THEN crewert:=$FF;
end;
procedure laufschrift(text:string);
VAR i,j,len :integer;
begin
  len:=length(text);
  FOR i:=0 TO len DO
  begin
    FOR j:=0 TO i DO
    writeport(crewert(text[i-j])),j);
    delay(1000);
  end;
end;
procedure spectrum;
VAR i,data :integer;
begin
writeln('Taste fr Abbruch');
Repeat
  randomize;
  For i:= 0 TO 5 DO
  begin
    data:=random(3);
    IF data=0 THEN writeport($FF,i);
    IF data=1 THEN writeport($F7,i);
    IF data=2 THEN writeport($B7,i);
    IF data=3 THEN writeport($B6,i);
  end;
  delay(1000);
UNTIL keypressed;
end;
procedure uhr;
Var hour, min, sek, hsek: word;
Begin
writeln('TASTE fr Abbruch');
REPEAT
  gettime(hour, min, sek, hsek);
  writeport(crewert(chr(hour DIV 10 +48)), 5);
  writeport(crewert(chr(hour MOD 10 +48))-$80, 4);
  writeport(crewert(chr(min DIV 10 +48)), 3);
  writeport(crewert(chr(min MOD 10 +48))-$80, 2);
  writeport(crewert(chr(sek DIV 10 +48)), 1);
  writeport(crewert(chr(sek MOD 10 +48)), 0);
UNTIL keypressed;
end;
procedure stoppuhr;
Var i: integer;
    hsek, sek, min, hsek2, sek2, min2, sek3, min3, x: word;
    key: char;
begin
writeln('ENTER fr START');
writeln('ENTER fr STOP');
writeln('a fr Abbruch');
writeport(crewert('0'), 0);
writeport(crewert('0'), 1);
writeport(crewert('0')+$80, 2);
writeport(crewert('0'), 3);
writeport(crewert('0')+$80, 4);
writeport(crewert('0'), 5);
REPEAT
  key:=readkey;
  IF ord(key) = 13 THEN
  Begin
    gettime(x, min, sek, hsek);
    REPEAT
      gettime(x, min2, sek2, hsek2);
      IF hsek2>=hsek THEN
        hsek2:=hsek2-hsek
      ELSE
        hsek2:=hsek2+100-hsek;
      IF (hsek2>=0) AND (hsek2<=5) THEN
      begin
        IF sek2>=sek THEN
          sek3:=sek2-sek
        ELSE
          sek3:=sek2+60-sek;
      end;
      IF (sek3>=0) AND (sek3<=1) THEN
      begin
        IF min2>=min THEN
          min3:=min2-min
        ELSE
          min3:=min2+60-min;
      end;
      writeport(crewert(chr(hsek2 MOD 10 + 48)), 0);
      writeport(crewert(chr(hsek2 DIV 10 + 48)), 1);
      writeport(crewert(chr(sek3  MOD 10 + 48)) +$48, 2);
      writeport(crewert(chr(sek3  DIV 10 + 48)), 3);
      writeport(crewert(chr(min3  MOD 10 + 48)) +$80, 4);
      writeport(crewert(chr(min3  DIV 10 + 48)), 5);
    UNTIL keypressed;
  readln;
  end;
UNTIL key= 'a';
end;
BEGIN
REPEAT
  FOR i:=0 TO 5 DO writeport(crewert(' '), i);
  clrscr;
  writeln('LED-Ausgabe');
  writeln;
  writeln;
  writeln('1 fr Uhr');
  writeln('2 fr Stoppuhr');
  writeln('3 fr Laufschrift');
  writeln('4 fr Spektrum');
  writeln('q fr Abbruch');
  choice:=readkey;
  CASE choise OF
    '1': uhr;
    '2': stoppuhr;
    '3': laufschrift('HELLO    ');
    '4': spectrum;
UNTIL choise='x';
END.
mr.escape mac4dac „Problem: es meldt immer einen Fehler beim Kompilieren ,“
Wo wird die variable "stelle1" von "writeport" definiert?
mr.escape
"The man who trades freedom for security does not deserve nor will he ever receive either." - Benjamin Franklin"Wer seine Freiheit aufgibt, um Sicherheit zu erreichen, wird beides verlieren." - Georg Christoph Lichtenberg
mac4dac mr.escape „Wo wird die variable stelle1 von writeport definiert? mr.escape“
ja aber trotzdem wenn ich es definiere in der Procedure oder ganz open im Hauptprogramm meldet es noch paar Fehler
mac4dac
mr.escape mac4dac „ja aber trotzdem wenn ich es definiere in der Procedure oder ganz open im...“
OK! Da du dir ja weitere infos aus der nase ziehen lassen willst, habe ich mal einen alten compiler rausgekramt und das kam dabei raus (ich musste den compiler gar nicht foltern, er hat auch so gesungen):
Variablen nicht definiert (i und stelle1), komma statt semikolon benutzt (procedure writeport) und CASE nicht geschlossen. Pfui!
Uses crt, DOS;
choice: char;
i :integer;
procedure writeport(wert:byte; stelle:byte);
VAR stelle1:byte;
begin
IF (stelle>=0) AND (stelle THEN
begin
delay(1);
port[$378]:=wert;
end;
end;
begin
end;
begin
len:=length(text);
FOR i:=0 TO len DO
begin
FOR j:=0 TO i DO
writeport(crewert(text[i-j]),j);
delay(1000);
end;
end;
procedure spectrum;
begin
writeln('Taste f?r Abbruch');
Repeat
randomize;
For i:= 0 TO 5 DO
begin
data:=random(3);
end;
delay(1000);
UNTIL keypressed;
end;
procedure uhr;
Begin
writeln('TASTE f?r Abbruch');
REPEAT
UNTIL keypressed;
end;
procedure stoppuhr;
Var i: integer;
key: char;
begin
writeln('ENTER f?r START');
writeln('ENTER f?r STOP');
writeln('a f?r Abbruch');
REPEAT
key:=readkey;
Begin
REPEAT
IF hsek2>=hsek THEN
hsek2:=hsek2-hsek
ELSE
IF (hsek2>=0) AND (hsek2 begin
IF sek2>=sek THEN
sek3:=sek2-sek
ELSE
sek3:=sek2+60-sek;
end;
IF (sek3>=0) AND (sek3 begin
IF min2>=min THEN
min3:=min2-min
ELSE
min3:=min2+60-min;
end;
UNTIL keypressed;
readln;
end;
UNTIL key= 'a';
end;
BEGIN
REPEAT
clrscr;
writeln;
writeln;
writeln('1 f?r Uhr');
writeln('2 f?r Stoppuhr');
writeln('3 f?r Laufschrift');
writeln('4 f?r Spektrum');
writeln('q f?r Abbruch');
choice:=readkey;
CASE choice OF
'1': uhr;
'2': stoppuhr;
'4': spectrum;
END;
UNTIL choice='x';
END.
Syntaktisch sollte es jetzt gehen, semantisch wirds spannend.
In der funktion "crewert" wäre übrigens ein "CASE" konstrukt viel besser als die vielen IFs und in "laufschrift" droht ein laufzeitfehler (FOR i:=0 TO len DO).
mr.escape
mr.escape Nachtrag zu: „OK! Da du dir ja weitere infos aus der nase ziehen lassen willst, habe ich mal...“
Ach und zusätzlich noch "choice" und "choise" vermischt!
mr.escape
mac4dac mr.escape „Ach und zusätzlich noch choice und choise vermischt! mr.escape“
hi,
vielen Dank alle, es hat teilweise funktioniert. Aber dises Teil "Laufschrift" net warum weiß ich net? es hat gezeigt aber hat sich nicht bewegt.
noch mal vielen Dank..
mac4dac
mr.escape mac4dac „hi, vielen Dank alle, es hat teilweise funktioniert. Aber dises Teil Laufschrift...“
vielen Dank alle ...
??? Bin ich schizophren oder was?
... es hat teilweise funktioniert. Aber dises Teil "Laufschrift" net ...
Erstens ist die erste for schleife zu lang und zweitens fehlt die endlosschleife "bis taste" (es läuft die schrift nur einmal rein und das wars dann), d.h.:
FOR i:=0 TO len DO
ersetzen durch:
Repeat
FOR i:=0 TO len-1 DO
und zwischen die zwei "end;" noch ein
UNTIL keypressed;
einfügen.
mr.escape
mac4dac mr.escape „ ??? Bin ich schizophren oder was? Erstens ist die erste for schleife zu lang...“
vielen vielen Dank für deine Hilfe, ich mein´s ernst. Ich hab 2 bekommen und es freut mich drüber.
danke na.
mac4dac
mr.escape mac4dac „ich bedanke mich bei dir mr.escape“
Gratuliere!
mr.escape
