Hallo Linux-Experten,
leider kann ich in Kubuntu 9.10 nicht drucken mit meinem HP Laserjet 1020. Da mich das allmählich zur Verzweiflung treibt, möchte ich dem Problem nun auf den Grund gehen.
dmesg | grep usb bringt folgende Ausgabe:
user@Aldi-PC:~$ dmesg | grep usb
[ 0.114872] usbcore: registered new interface driver usbfs
[ 0.114896] usbcore: registered new interface driver hub
[ 0.114946] usbcore: registered new device driver usb
[ 0.828144] usb usb1: configuration #1 chosen from 1 choice
[ 0.828617] usb usb2: configuration #1 chosen from 1 choice
[ 0.828951] usb usb3: configuration #1 chosen from 1 choice
[ 0.829306] usb usb4: configuration #1 chosen from 1 choice
[ 0.829654] usb usb5: configuration #1 chosen from 1 choice
[ 1.144112] usb 1-2: new high speed USB device using ehci_hcd and address 2
[ 1.312103] usb 1-2: configuration #1 chosen from 1 choice
[ 1.437676] usb 1-3: new high speed USB device using ehci_hcd and address 3
[ 1.688224] usb 1-3: configuration #1 chosen from 1 choice
[ 1.696085] usbcore: registered new interface driver usb-storage
[ 1.696364] usb-storage: device found at 2
[ 1.696369] usb-storage: waiting for device to settle before scanning
[ 1.833517] usb 1-8: new high speed USB device using ehci_hcd and address 4
[ 2.052963] usb 1-8: configuration #1 chosen from 1 choice
[ 2.055246] usb-storage: device found at 4
[ 2.055249] usb-storage: waiting for device to settle before scanning
[ 6.696254] usb-storage: device scan complete
[ 7.057757] usb-storage: device scan complete
[ 87.195376] usblp0: USB Bidirectional printer dev 3 if 0 alt 0 proto 2 vid 0x03F0 pid 0x2B17
[ 87.195420] usbcore: registered new interface driver usblp
[ 92.663100] usblp0: removed
[ 98.780227] usb 1-3: usbfs: USBDEVFS_CONTROL failed cmd hp rqt 128 rq 6 len 255 ret -110
[ 98.780641] usb 1-3: usbfs: USBDEVFS_CONTROL failed cmd usb rqt 161 rq 0 len 1024 ret -110
[ 99.364156] usb 1-3: usbfs: USBDEVFS_CONTROL failed cmd python rqt 128 rq 6 len 255 ret -110
cat /var/log/cups/error_log bringt folgende Ausgabe:
E [27/May/2010:14:33:29 +0200] Unable to remove temporary file "/var/spool/cs/tmp/.hplip" - Is a directory
E [27/May/2010:14:40:17 +0200] cupsdReadClient: 23 IPP Read Error!
E [27/May/2010:17:47:51 +0200] Unable to remove temporary file "/var/spool/cs/tmp/.hplip" - Is a directory
Ich hoffe, Ihr könnt daraus etwas lesen, was mir hilft.
miraculix926
PS.: Die Angaben zu Mandriva folgen später, eventuell auch erst morgen, weil ich heute noch arbeiten muss.
ist das Paket:
foo2zjs
installiert?
Bitte lies mal hier nach:
http://wiki.ubuntuusers.de/HP_Laserjet_10xx
Hallo miraculix926,
lese bitte dazu in diesen Thread das sollte dein Problem lösen.
MfG Acader
Hallo Acader und cscherwinski,
Der HP PSC 1415 unter Mandriva 2010.0 läuft wieder! Nachdem ich in Windows Vista (auf dem gleichen Rechner) etwas ausgedruckt hatte, konnte ich in Mandriva auch wieder drucken. Die Ursache des Problems war, dass der Drucker eine Woche lang ausgeschaltet war. Es läuft also genauso wie auf dem anderen Rechner vorher mit Ubuntu 8.04LTS und Windows XP.
Bleibt also noch der andere Drucker. Damit befasse ich mich gleich auch noch. Schönen Dank erst einmal für Eure Tips.
miraculix 926
Melde Dich wenns nicht gehen sollte mit dem anderen Drucker.
Schön daß es nun läuft!
Hallo cscherwinski und Acader,
Hurra, es klappt jetzt mit beiden Druckern! Den HP-Laserjet-1020 habe noch einmal über CUPS installiert, und jetzt kann ich wieder drucken! Schönen Dank noch einmal für Eure Hilfe!
miraculix926
Das ist eine gute Nachricht miraculix!
Dann ein schönes Wochenende!
