X3100 Kubuntu - nur noch 640x480
PingOfDeath / 2 Antworten / Baumansicht Nickles
ich wollte gerade eine Präsentation vorbereiten da macht mir mein Kubuntu einen Strich durch die Rechnung :-(
Habe plötzlich nur noch 640x480 Bildpunkte und kann das nicht mehr umstellen.
In der xorg.conf steht :
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "de"
Option "XkbVariant" "nodeadkeys"
Option "XkbOptions" "lv3:ralt_switch"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizEdgeScroll" "0"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4"# Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller"
Boardname "VESA driver (generic)"
Busid "PCI:0:2:0"
Driver "intel"
Screen 0
EndSection
Section "Monitor"
Identifier "Standardbildschirm"
Vendorname "Plug 'n' Play"
Modelname "Plug 'n' Play"
modeline "640x480@60" 25.2 640 656 752 800 480 490 492 525 -vsync -hsync
Gamma 1.0
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller"
Monitor "Standardbildschirm"
Defaultdepth 24
SubSection "Display"
Depth 24
Virtual 640 480
Modes "640x480@60" "800x600@60" "1280x800@60"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen 0 "Default Screen" 0 0
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
# Uncomment if you have a wacom tablet
# InputDevice "stylus" "SendCoreEvents"
# InputDevice "cursor" "SendCoreEvents"
# InputDevice "eraser" "SendCoreEvents"
Inputdevice "Synaptics Touchpad"
EndSection
Section "Module"
Load "glx"
Load "GLcore"
Load "v4l"
EndSection
Section "device" #
Identifier "device1"
Busid "PCI:0:2:0"
Driver "vesa"
Screen 1
EndSection
Section "screen" #
Identifier "screen1"
Device "device1"
Defaultdepth 24
Monitor "monitor1"
Depth 24
Modes "640x480@60"
EndSubSection
EndSection
Section "monitor" #
Identifier "monitor1"
Gamma 1.0
EndSection
Section "device" #
Identifier "device2"
Busid "PCI:0:2:1"
Driver "vesa"
Screen 0
EndSection
Section "screen" #
Identifier "screen2"
Device "device2"
Defaultdepth 24
Monitor "monitor2"
Depth 24
Modes "640x480@60"
EndSubSection
EndSection
Section "monitor" #
Identifier "monitor2"
Gamma 1.0
EndSection
Section "ServerFlags"
EndSection
Es ist ein AMILO LI 2727 Laptop mit einem Display welches 1280x800 darstellen kann.
Kann mir jemand sagen wie ich das schnell wieder hinbekomme - brauche das Gerät dringend am Sa.
Gruß und vielen Dank!
Tuxus PingOfDeath „X3100 Kubuntu - nur noch 640x480“
wenn die xorg.conf verändert wird, wird automatisch ein Backup erstellt. Schau mal in /etc/X11/ ob Du ältere Versionen Deiner xorg.conf findest.
Diese kannst Du öffnen und nachsehen, welcher Unterschied besteht.
Deine xorg.conf hat folgende Merkwürdigkeiten:
1.
Alles, was hieran folgt ist für mich nicht klar, z.B. folgen obige Einträge nochmal, siehe InputDevice "Touchpad Synaptics" oder es werden neue Monitore und Devices dafür konfiguriert.
Ehrlich gesagt würde ich das ganze Zeugs löschen. Ich vermute, das entstand durch Deine Rettungsversuche.
2. Du hast auch nur diese Auflösung ausgesucht:
Section "Monitor"
Gamma 1.0
EndSection
Section "Screen"
Defaultdepth 24
Depth 24
Virtual 640 480
EndSubSection
EndSection
Man könnte nun die fetten Zeilen löschen. Vorher aber ein Backup machen: sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf.bak
Wegen des Gerummseln am Ende, würde ich jedoch die xorg.conf neu erstellen mit: sudo dpkg-reconfigure xserver-xorg
Anleitung hier: http://wiki.ubuntuusers.de/XServer_einrichten
Schönen Abend,
tuxus
PingOfDeath Tuxus „Hi, wenn die xorg.conf verändert wird, wird automatisch ein Backup erstellt....“
Danke für Deine Hilfe - es läuft wieder.
Am längsten hing ich an dem Fehler, dass ich den VESA Treiber (zu testzwecken) eingestellt hatte. Die X3100 scheint bei mir NUR mit dem intel Treiber zu laufen ;-)
Gruß, PingOfDeath
