Hallo!
Es handelt sich dabei um eine Doppelanfrage (in einem anderen Forum wurde auch nach bumping und verstrichenen 3 Tagen nicht geantwortet :-( ).
Ich habe zur meinen Archiv-DVD eine neue Session mit:
growisofs -M /dev/hdb -R -J /neues/file
zugefügt; die DVD lässt sich nachdem nicht einlesen:
:~$ sudo mount /dev/hdb
mount: block device /dev/hdb is write-protected, mounting read-only
:~$ mount
/dev/hdb on /media/cdrom0 type iso9660 (ro,nosuid,nodev)
:~$ cd /media/cdrom0
:/media/cdrom0$ ls
:/media/cdrom0$
:~$ dvd+rw-mediainfo /dev/hdb
2 INQUIRY: [SONY ][DVD RW DW-D23A ][CYS1]
3 GET [CURRENT] CONFIGURATION:
4 Mounted Media: 1Bh, DVD+R
5 Media ID: OPTODISC/OR8
6 Current Write Speed: 8.0x1385=11080KB/s
7 Write Speed #0: 8.0x1385=11080KB/s
8 Write Speed #1: 6.0x1385=8310KB/s
9 Write Speed #2: 4.0x1385=5540KB/s
10 GET [CURRENT] PERFORMANCE:
11 Write Performance: 3.2x1385=4432KB/s@0 -> 6.4x1385=8888KB/s@1539727
12 Speed Descriptor#0: 00/1539727 R@6.4x1385=8888KB/s W@8.0x1385=11080KB/s
13 Speed Descriptor#1: 00/1539727 R@6.4x1385=8888KB/s W@6.0x1385=8310KB/s
14 Speed Descriptor#2: 00/1539727 R@6.4x1385=8888KB/s W@4.0x1385=5540KB/s
15 READ DVD STRUCTURE[#0h]:
16 Media Book Type: 00h, DVD-ROM book [revision 0]
17 Legacy lead-out at: 2295104*2KB=4700372992
18 READ DISC INFORMATION:
19 Disc status: appendable
20 Number of Sessions: 6
21 State of Last Session: incomplete
22 "Next" Track: 6
23 Number of Tracks: 10
24 READ TRACK INFORMATION[#1]:
25 Track State: invisible
26 Track Start Address: 0*2KB
27 Free Blocks: 0*2KB
28 Track Size: 101664*2KB
29 ROM Compatibility LBA: 262144
30 READ TRACK INFORMATION[#2]:
31 Track State: invisible
32 Track Start Address: 103712*2KB
33 Free Blocks: 0*2KB
34 Track Size: 27200*2KB
35 ROM Compatibility LBA: 262144
36 READ TRACK INFORMATION[#3]:
37 Track State: invisible
38 Track Start Address: 132960*2KB
39 Free Blocks: 0*2KB
40 Track Size: 1091664*2KB
41 ROM Compatibility LBA: 262144
42 READ TRACK INFORMATION[#4]:
43 Track State: invisible
44 Track Start Address: 1226672*2KB
45 Free Blocks: 0*2KB
46 Track Size: 310432*2KB
47 ROM Compatibility LBA: 262144
48 READ TRACK INFORMATION[#5]:
49 Track State: invisible
50 Track Start Address: 1539152*2KB
51 Free Blocks: 0*2KB
52 Track Size: 576*2KB
53 ROM Compatibility LBA: 262144
54 READ TRACK INFORMATION[#6]:
55 Track State: reserved
56 Track Start Address: 1541776*2KB
57 Next Writable Address: 1541776*2KB
58 Free Blocks: 304*2KB
59 Track Size: 304*2KB
60 READ TRACK INFORMATION[#7]:
61 Track State: reserved
62 Track Start Address: 1542096*2KB
63 Next Writable Address: 1542096*2KB
64 Free Blocks: 304*2KB
65 Track Size: 304*2KB
66 READ TRACK INFORMATION[#8]:
67 Track State: reserved
68 Track Start Address: 1542416*2KB
69 Next Writable Address: 1542416*2KB
70 Free Blocks: 304*2KB
71 Track Size: 304*2KB
72 READ TRACK INFORMATION[#9]:
73 Track State: reserved
74 Track Start Address: 1542736*2KB
75 Next Writable Address: 1542736*2KB
76 Free Blocks: 304*2KB
77 Track Size: 304*2KB
78 READ TRACK INFORMATION[#10]:
79 Track State: blank
80 Track Start Address: 1543056*2KB
81 Next Writable Address: 1543056*2KB
82 Free Blocks: 752048*2KB
83 Track Size: 752048*2KB
84 ROM Compatibility LBA: 262144
85 FABRICATED TOC:
86 Track#1 : 14@0
87 Track#2 : 14@103712
88 Track#3 : 14@132960
89 Track#4 : 14@1226672
90 Track#5 : 14@1539152
91 Track#AA : 14@1539728
92 Multi-session Info: #5@1539152
93 READ CAPACITY: 1539728*2048=3153362944
Danke im Voraus!
Gena
Vergiss dieses Programm growisofs. Damit hatte ich auch nur Probleme.
Nimm nero für Linux:
http://www.nero.com/deu/linux3.html
Die Testversion ist voll lauffähig. Du mußt dir nur noch eine gültige Seriennummer besorgen.
@KarstenW
Danke!
Ich habe deb-Paket auf Anhieb installiert; werde probieren damit zu Arbeiten.
So, wie ich verstanden habe, war das Schweigen im anderen Forum nicht unbegründet?
Also diese DVD+RW ist nicht zu retten?
Danke!
Gena
Hallo!
Es geht einfach; DVD wird erkannt, eingelesen.
Einfach noch mal probiert ...
Gena
Ich habe bei Debian sarge mit diesem Programm keine guten Erfahrungen gemacht.
Die Daten wurden teilweise fehlerhaft kopiert.
CDs Brennen mit cdrecord oder cdrdao war noch nie ein Problem.
Ich würde nero nutzen. Du kannst nero auch in der Kommadozeile starten.
