hallo ..warum?
was ich auch ändere..immmer sinds 2 minuten
hier meine lilo.conf
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
boot="/dev/hda"
default = linux
prompt
compact
#delay = 1
timeout="10"
# Override dangerous defaults that rewrite the partition table:
change-rules
reset
bitmap = /boot/bitmap/boot.bmp
# Normal VGA console
vga="Standar"
# VESA framebuffer console @ 1024x768x64k
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# VESA framebuffer console @ 1024x768x256
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# End LILO global section
# Partition 1: Linux GUI mode
image = /boot/vmlinuz
root = /dev/hda2
label = dodahdruckn
append = " "
read-only
# Partition 2: Linux TUI mode
root = /dev/hda2
label = linux-tui
append = "2 "
read-only
# Partition 3: Linux GUI mode
root = /dev/hda2
label = linux-gui
append = "4 "
read-only
# Partition 4: Linux
image = /boot/vmlinuz-sata-2.4.29
root = /dev/hda2
label = sata-2.4.29
append = " "
read-only
irgendwelche ideen?
heut is nicht mein tag..siehe threads
gruss günter
ps..bei timeout = "10"...im vi sind keine komma
hab das rauskopiert aus dem kontrollcenter
komisch...
