NO PING von freeswan gateway zu remote machines !
anonimous / 0 Antworten / Baumansicht Nickles
habe ernstahftes problem mit freeswan gateway ( linux SuSE 8.2 ) ,
verbunden via ipsec tunnel mit Watchguard firewall.
Auf dem linux gateway habe 2 interfaces :
eth0 (externes) mit einer Internet adresse (212.X.X.X) und
eth1 (internes) mit einer privater adresse (192.168.115.1)
mein ipsec.conf :
config setup
interfaces=%defaultroute
klipsdebug=none
plutodebug=none
plutoload=%search
plutostart=%search
uniqueids=yes
forwardcontrol=yes
conn %default
keyingtries=0
disablearrivalcheck=no
authby=secret
#compress=yes
#leftrsasigkey=%dnsondemand
#rightrsasigkey=%dnsondemand
conn roadwarrior
left=%any
conn me-to-anyone
#left=%defaultroute
#right=%opportunistic
#keylife=1h
#rekey=no
# for initiator only OE,
# after putting your key
#leftid=@myhostname.example.com
# uncomment this next line to enable it
# auto=route
conn Firebox1
left=195.X.X.X
leftnexthop=%defaultroute
leftsubnet=192.168.0.0/24
right=212.X.X.X
rightnexthop=%defaultroute
rightsubnet=192.168.115.0/24
leftupdown=/usr/lib/ipsec/_updown_custom
auto=start
Der tunnel funktioniert.
# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
212.X.X.X * 255.255.255.240 U 0 0 0 eth0
212.X.X.X * 255.255.255.240 U 0 0 0 ipsec0
192.168.0.0 gw.xxx.net 255.255.255.0 UG 0 0 0 ipsec0
192.168.115.0 * 255.255.255.0 U 0 0 0 eth1
default gw.xxx.net 0.0.0.0 UG 0 0 0 eth0
# ipsec verify
Checking your system to see if IPsec was installed and started correctly
Version check and ipsec on-path [OK]
Checking for KLIPS support in kernel [OK]
Checking for RSA private key (/etc/ipsec.secrets) [OK]
Checking that pluto is running [OK]
DNS checks.
Looking for forward key for ext [FAILED]
Looking for TXT in reverse map: X.X.X.212.in-addr.arpa [OK]
Does the machine have at least one non-private address [OK]
I kann von jeder remote maschine linux gateway anpingen,
aber NICHT umgekehrt !
auf der linux gateway seite läuft keine firewall.
auf der remote seite, sind alle ports "ANY to ANY" für linux erlaubt.
