Fehler beim Kompilieren von avifile
Fridolin Michel / 5 Antworten / Baumansicht Nickles
Hallo!
Ich wollte avifile-0.7-0.7.38 mit "make" kompilieren und erhalte unten stehende Fehlermeldung. Das Konfigurieren mit "./configure" lief dagegen Problemlos ab.
Making all in . make[1]: Entering directory `/root/avifile-0.7-0.7.38' make[1]: Nothing to be done for `all-am'. make[1]: Leaving directory `/root/avifile-0.7-0.7.38'
Making all in admin make[1]: Entering directory `/root/avifile-0.7-0.7.38/admin'
make[1]: Nothing to be done for `all'. make[1]: Leaving directory `/root/avifile-0.7-0.7.38/admin'
Making all in m4 make[1]: Entering directory `/root/avifile-0.7-0.7.38/m4'
make[1]: Nothing to be done for `all'. make[1]: Leaving directory `/root/avifile-0.7-0.7.38/m4'
Making all in ffmpeg make[1]: Entering directory `/root/avifile-0.7-0.7.38/ffmpeg'
Making all in libavformat make[2]: Entering directory `/root/avifile-0.7-0.7.38/ffmpeg/libavformat' /bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../../include -DHAVE_AV_CONFIG_H -I./../libavcodec -I./.. -Wall -Wno-unused -I../../include -O2 -mcpu=i686 -march=i686 -ffast-math -fomit-frame-pointer -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -D_GNU_SOURCE -pipe -c flvenc.c gcc -DHAVE_CONFIG_H -I. -I. -I../../include -DHAVE_AV_CONFIG_H -I./../libavcodec -I./.. -Wall -Wno-unused -I../../include -O2 -mcpu=i686 -march=i686 -ffast-math -fomit-frame-pointer -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -D_GNU_SOURCE -pipe -c flvenc.c -fPIC -DPIC -o flvenc.lo flvenc.c: In function `flv_write_trailer': flvenc.c:232: parse error before `file_size' flvenc.c:234: `flags' undeclared (first use in this function) flvenc.c:234: (Each undeclared identifier is reported only once flvenc.c:234: for each function it appears in.) flvenc.c:238: `file_size' undeclared (first use in this function)
make[2]: *** [flvenc.lo] Error 1 make[2]: Leaving directory `/root/avifile-0.7-0.7.38/ffmpeg/libavformat'
make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/root/avifile-0.7-0.7.38/ffmpeg' make: *** [all-recursive] Error 1
Frido
NANÜ Fridolin Michel „Fehler beim Kompilieren von avifile“
das bedarf es offensichtlich keines make, sondern eher eines Makefile, ansonsten suche dir doch eine RPM-Datei unter http://www.rpmseek.com/index.html oder unter http://www.rpmfind.net.
Grüße aus ZA
cu
NANÜ
P.S. HIER..........genug zur Auswahl
NANÜ Nachtrag zu: „das bedarf es offensichtlich keines make, sondern eher eines Makefile, ansonsten...“
ungenauer Link http://rpmseek.com/rpm-pl/avifile.html?hl=de&cs=avifile:PN:0:0:0:0, die für dich richtige SW findest du schon..........
Fridolin Michel NANÜ „das bedarf es offensichtlich keines make, sondern eher eines Makefile, ansonsten...“
Natürlich bedarf es einer Makefile. Die will ich ja gerade mit "make" erstellen. Bei rpmseek gibt es nichts für Debian, denn das Packetformat für Debian heißt .deb und nicht .rpm. Da ich keine aktuelle avifile im deb-Format gefunden habe, will ich eben avifile als Source(.src) installieren. Das eigentliche Problem muss aber irgendwo bei ffmpeg liegen, wie der Fehlermeldung zu entnehmen ist.
hi Fridolin,
hast natürlich Recht, aber ich bin nicht von Debian (nicht meine Hauptdistri, mehr ein Hobby für nebenbei, möchte Debian nicht als Desktopdistri nutzen wollen, müssen) ausgegangen..................schade, dachte es hilft dir weiter.
cu
NANÜ
Fridolin Michel Nachtrag zu: „Fehler beim Kompilieren von avifile“
Trotzdem danke für deine Bemühungen.
Frido
