Hallo!
Bekomme bei der Installation von "SPAZZ" (ACDSee-Clone) immer folgende Meldung:
- checking for GTK - version >=1.2.0... yes
- checking for gdk-pixbuf-config... no
- checking for GDK_PIXBUF - version >=0.7.0... no
- ***The gdk-pixbuf-config script installed by GDK_PIXBUF could not be found
- ***If GDK_PIXBUF was installed in PREFIX, make sure PREFIX/BIN is in
- ***your path, or set the GDK_PIXBUF_CONFIG environment variable to the
- ***full path to gdk-pixbuf-config.
- configure: error: gdk-pixbuf 0.7.0 or higher required
Wie komme ich hier weiter??
Danke
Steht doch da: gdk-pixbuf installieren, das komplette Paket mit den devels.
Klaus
