Kernel 2.4.1 will sich nicht übersetzen lassen
bedenick / 1 Antworten / Baumansicht Nickles
Moin,
ich habe verzweifelt versucht, den 2.4.1-er Kernel zu übersetzen.
Die Software, die benötigt wird (gcc, libs, make etc.) habe ich
angeblich alle in der richtigen Version.
Allerdings schmeißt das Make nach kurzer Zeit folgende Fehlermeldung:
/usr/src/linux/include/asm/hw_irq.h: In function `x86_do_profile\':
In file included from /usr/src/linux/include/linux/irq.h:57,
from /usr/src/linux/include/asm/hardirq.h:6,
from /usr/src/linux/include/linux/interrupt.h:45,
from /usr/src/linux/include/asm/string.h:296,
from /usr/src/linux/include/linux/string.h:21,
from /usr/src/linux/include/linux/fs.h:23,
from /usr/src/linux/include/linux/capability.h:17,
from /usr/src/linux/include/linux/binfmts.h:5,
from /usr/src/linux/include/linux/sched.h:9,
from /usr/src/linux/include/linux/mm.h:4,
from /usr/src/linux/include/linux/slab.h:14,
from /usr/src/linux/include/linux/malloc.h:4,
from /usr/src/linux/include/linux/proc_fs.h:5,
from init/main.c:15:
/usr/src/linux/include/asm/hw_irq.h:198: `current\' undeclared (first use in this function)
/usr/src/linux/include/asm/hw_irq.h:198: (Each undeclared identifier is reported only once
/usr/src/linux/include/asm/hw_irq.h:198: for each function it appears in.)
/usr/src/linux/include/linux/interrupt.h: In function `raise_softirq\':
In file included from /usr/src/linux/include/asm/string.h:296,
/usr/src/linux/include/linux/interrupt.h:89: `current\' undeclared (first use in this function)
/usr/src/linux/include/linux/interrupt.h: In function `tasklet_schedule\':
/usr/src/linux/include/linux/interrupt.h:160: `current\' undeclared (first use in this function)
/usr/src/linux/include/linux/interrupt.h: In function `tasklet_hi_schedule\':
/usr/src/linux/include/linux/interrupt.h:174: `current\' undeclared (first use in this function)
/usr/src/linux/include/asm/string.h: In function `__constant_memcpy3d\':
In file included from /usr/src/linux/include/linux/string.h:21,
/usr/src/linux/include/asm/string.h:305: `current\' undeclared (first use in this function)
/usr/src/linux/include/asm/string.h: In function `__memcpy3d\':
/usr/src/linux/include/asm/string.h:312: `current\' undeclared (first use in this function)
make: *** [init/main.o] Error 1
Was nun? Ich habe die Kernel-Sourcen nach /usr/src/linux-2.4.1 entpackt, einen Link
nach /usr/src/linux gemacht, so wie ich es von 2.2.16-er gewöhnt bin.
Den zu übersetzen klappt auch weiterhin...
Für Hilfe dankbar...
Bernhard
bderks@web.de
axel_flettner (Anonym) bedenick „Kernel 2.4.1 will sich nicht übersetzen lassen“
Hallo Bernhard !
versuch doch mal ein anderes Verzeichnis in das du die neuen Kernelquellen installieren kannst. Im Kernel-README steht glaub ich drin das man eben nicht das /usr/src-Verzeichnis wählen soll da dies zu Problemen führen kann !
Ich habe z.B. den Kernel in ein Scratchverzeichnis entpackt und es lief alles normal !
Ich mußte allerdings so vorgehen :
make mrproper
make xconfig
Bzw. manchmal startete "make xconfig" nicht und ich habe dann noch ein "make clean" nach dem "make mrproper" gemacht !
Aber mit etwas Ausdauer gings dann problemlos !
hoffentlich hilfts dir was !
gruß Axel
