GO!LINUX Sound verschwindet
SPEEDY (Anonym) / 3 Antworten / Baumansicht Nickles
Erfreulicherweise war es mir unter GO!LINUX zum ersten mal möglich einen
Sound ohne das OSS-Paket zu installieren!
sndconfig --noautoconfig und durchprobiert bis es klappte.
Dann unter KDE Systemklänge eingestellt und alles funktionierte bis auf Midi.
Nach dem nächsten Reboot hörte ich nur noch Knackgeräusche.
Was kann da los sein? Hier ein Auszug aus den messages:
May 20 22:11:28 localhost kernel: ad1848/cs4248 codec driver Copyright (C) by Hannu Savolainen 1993-1996
May 20 22:11:28 localhost atd: atd startup succeeded
May 20 22:11:29 localhost crond: crond startup succeeded
May 20 22:11:29 localhost rc: Starting pcmcia succeeded
May 20 22:11:11 localhost rc.sysinit: Mounting proc filesystem succeeded
May 20 22:11:11 localhost rc.sysinit: Turning off Magic SysRq key succeeded
May 20 22:11:11 localhost date: Sat May 20 22:11:10 CEST 2000
May 20 22:11:11 localhost rc.sysinit: Setting clock : Sat May 20 22:11:10 CEST 2000 succeeded
May 20 22:11:11 localhost rc.sysinit: Activating swap partitions succeeded
May 20 22:11:11 localhost rc.sysinit: Setting hostname localhost.localdomain succeeded
May 20 22:11:11 localhost fsck: /dev/hdb5: clean, 60102/1015808 files, 1172252/2028198 blocks
May 20 22:11:11 localhost rc.sysinit: Checking root filesystem succeeded
May 20 22:11:11 localhost isapnp: Board 1 has Identity 8d 01 00 01 00 01 00 a9 0d: CMI0001 Serial No 16777472 [checksum 8d]
May 20 22:11:11 localhost isapnp: CMI0001/16777472[0]{CMI8330/C3D Audio Adapter}: Port 0x530; IRQ9 --- Enabled OK
May 20 22:11:11 localhost isapnp: CMI0001/16777472[1]{CMI8330/C3D Audio Adapter}: Port 0x330; IRQ5 --- Enabled OK
May 20 22:11:11 localhost isapnp: CMI0001/16777472[2]{CMI8330/C3D Audio Adapter}: --- Enabled OK
May 20 22:11:11 localhost isapnp: CMI0001/16777472[3]{CMI8330/C3D Audio Adapter}: DMA0 --- Enabled OK
May 20 22:11:11 localhost rc.sysinit: Setting up ISA PNP devices succeeded
May 20 22:11:11 localhost rc.sysinit: Remounting root filesystem in read-write mode succeeded
May 20 22:11:17 localhost rc.sysinit: Finding module dependencies succeeded
May 20 22:11:17 localhost rc.sysinit: Loading sound module succeeded
May 20 22:11:17 localhost rc.sysinit: Loading midi module succeeded
May 20 22:11:17 localhost aumix-minimal: vol set to 72, 72
May 20 22:11:17 localhost rc.sysinit: Loading mixer settings succeeded
May 20 22:11:17 localhost aumix-minimal: synth set to 75, 75
May 20 22:11:17 localhost aumix-minimal: pcm set to 78, 78
May 20 22:11:17 localhost aumix-minimal: speaker set to 58, 58
May 20 22:11:17 localhost aumix-minimal: line set to 32, 32, P
May 20 22:11:17 localhost aumix-minimal: mic set to 16, 16, R
May 20 22:11:17 localhost aumix-minimal: cd set to 88, 88, P
May 20 22:11:17 localhost aumix-minimal: ogain set to 100, 100
May 20 22:11:17 localhost aumix-minimal: line1 set to 32, 32, P
May 20 22:11:20 localhost init: Entering runlevel: 5
May 20 22:11:26 localhost kudzu: succeeded
May 20 22:11:27 localhost apmd[257]: Version 3.0beta9 (APM BIOS 1.2, Linux driver 1.9)
May 20 22:11:30 localhost rc: Starting ssh succeeded
May 20 22:11:34 localhost httpd: httpd startup succeeded
May 20 22:11:35 localhost xfs: xfs startup succeeded
May 20 22:11:36 localhost FaxQueuer[530]: No etc/setup.cache file; run faxsetup(1M) first
May 20 22:11:36 localhost faxq: faxq startup failed
May 20 22:11:39 localhost rc: Starting linuxconf succeeded
May 20 22:12:06 localhost kernel: Sound: DMA (output) timed out - IRQ/DRQ config error?
May 20 22:12:08 localhost last message repeated 2 times
May 20 22:12:09 localhost modprobe: can't locate module synth0
May 20 22:12:09 localhost kernel: Sound: DMA (output) timed out - IRQ/DRQ config error?
May 20 22:12:11 localhost last message repeated 2 times
May 20 22:12:11 localhost modprobe: can't locate module synth0
May 20 22:12:12 localhost kernel: Sound: DMA (output) timed out - IRQ/DRQ config error?
May 20 22:12:12 localhost kernel: mpu401: Send data timeout
May 20 22:12:13 localhost last message repeated 4 times
May 20 22:12:13 localhost kernel: Sound: DMA (output) timed out - IRQ/DRQ config error?
May 20 22:12:13 localhost kernel: mpu401: Send data timeout
May 20 22:12:14 localhost last message repeated 3 times
May 20 22:12:15 localhost kernel: Sound: DMA (output) timed out - IRQ/DRQ config error?
May 20 22:12:15 localhost kernel: mpu401: Send data timeout
May 20 22:12:16 localhost last message repeated 3 times
May 20 22:13:10 localhost last message repeated 16 times
Was sind das für Fehlermeldungen?
Anonym SPEEDY (Anonym) „GO!LINUX Sound verschwindet“
Die Meldung sagt Dir, daß ein Zugriff auf den DMA Kanal nicht
möglich ist. Da Du mittels isapnp die Einstellungen
irq=9,io=530 sowie irq=5,io=330 erfolgreich einstellen kontest,
vermute ich, daß in /etc/conf.moduls andere/falsche/alte Werte
stehen.
j.
(Anonym) Anonym „ kernel: Sound: DMA output timed out - IRQ/DRQ config error?Die Meldung sagt...“
unter anderem sind auch diese Werte in der /etc/conf.modules.
Aber warum kann es sndconfig richtig testen und nicht auch richtig eintragen?
(Anonym) SPEEDY (Anonym) „GO!LINUX Sound verschwindet“
Problem scheint momentan gelöst mit Einstellung WSS statt Adlib.
Hab aber noch nicht alles ausgetestet.
