Probleme mit Gnome Display Manager (gdm)
Ralf / 0 Antworten / Baumansicht Nickles
Ich habe Probleme mit dem gdm.
In den Doku's steht :
3. The Greeter
The greeter is the graphical login window appearing on each display
when gdm is started.
On startup the greeter looks for icons in every user's homedir. For
performance reasons this can be turned off by disabling the face
browser.
~user/.gnome/photo is expected to contain an Imlib supported
image. gdmgreeter will scale down large images to the sysadmin
specified maximum.
Ich habe wie im Text beschrieben jeweils bei /home/username/.gnome/photo ein zuerst PNG dann JPG
WAS HABE ICH FALSCH GEMACHT,bzw. übersehen ?
hier meine gdm.conf
[appearance]
Browser=1
Completion=1
Logo=1
LogoImage=/usr/share/pixmaps/gnome-logo-large.png
NoFaceImage=/usr/share/pixmaps/nophoto.png
GlobalImageDir=/usr/share/faces/
Quiver=1
Iconify=1
IconFile=/usr/share/pixmaps/gdm.xpm
Gtkrc=
[system]
ShutdownMenu=1
SuspendCommand=
UserFileCutoffSize=65536
UserIconMaxWidth=128
UserIconMaxHeight=128
DefaultPath=/usr/local/bin:/usr/bin/X11:/usr/bin:/bin
[messages]
Welcome=Welcome to %h
[daemon]
SessionDir=/etc/gdm/Sessions
PidFile=/var/run/gdm.pid
Greeter=/usr/sbin/gdmgreeter --disable-sound
Chooser=/usr/sbin/gdmchooser --disable-sound
User=nobody
Group=daemon
DisplayInitDir=/etc/gdm/Init
KillInitClients=1
PreSessionScriptDir=/etc/gdm/PreSession
PostSessionScriptDir=/etc/gdm/PostSession
AuthDir=/var/state/gdm/authdir
LogDir=/var/state/gdm
[servers]
0=/usr/bin/X11/X
#1=/usr/bin/X11/X
[xdmcp]
Enable=1
MaxLoadAvg=10
MaxPending=4
MaxManageWait=20
MaxSessions=4
Port=177
[chooser]
ImageDir=/usr/share/hosts
DefaultImage=/usr/share/pixmaps/nohost.png
[debug]
Enable=0
(Ralf)
