Spiele - Konsolen, PC, online, mobil 8.980 Themen, 42.673 Beiträge
problem nit Quake 3 A
Amadeus / 4 Antworten / Baumansicht Nickles
ich habe folgendes problem ich starte quake und es erscheint ind er console folgendes
Q3 1.30 win-x86 Aug 20 2001
----- FS_Startup -----
Current search path:
C:\\Programme\\Quake III Arena\\baseq3\\pak6.pk3 (64 files)
C:\\Programme\\Quake III Arena\\baseq3\\pak5.pk3 (7 files)
C:\\Programme\\Quake III Arena\\baseq3\\pak4.pk3 (272 files)
C:\\Programme\\Quake III Arena\\baseq3\\pak3.pk3 (4 files)
C:\\Programme\\Quake III Arena\\baseq3\\pak2.pk3 (148 files)
C:\\Programme\\Quake III Arena\\baseq3\\pak1.pk3 (26 files)
C:\\Programme\\Quake III Arena\\baseq3\\pak0.pk3 (3539 files)
C:\\Programme\\Quake III Arena/baseq3
4060 files in pk3 files
execing default.cfg
execing q3config.cfg
couldn\'t exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn\'t set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( \'C:\\WIN\\SYSTEM\\opengl32.dll\' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming \'3dfxvgl\' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
kann einer mir sagen wie ich das viech zum laufen kriege
PS vor meinem totalcrasch lief es auf dem gleichensystem sauber.
Danke blinky
Dunkle Seite Amadeus „problem nit Quake 3 A“
na ja... da hat´s dir irgendetwas zerschossen ;-) Ich meine was für ein System hast du denn, was für`n Os usw.
Schon mal Q neu installiert, die Grakatreiber ect..
Bißchen mehr Info wäre net schlecht.
cu
Amadeus Nachtrag zu: „problem nit Quake 3 A“
also q3 hab ich gerade erst installiert OS winme system is p3 mit 64 mbram (bald mehr) grafik is eigentlich scheiße (intel 810) aber das ging ja vorm halben jahr noch
cu
XThi Amadeus „problem nit Quake 3 A“
hallo blinky
1. installiere den grafikkarten treiber neu
2. lösch' die config.cfg im baseq3 verzeichnis
CU [UNIX] MrX
thx
