Soundkarte
KingLuis942 / 3 Antworten / Baumansicht Nickles
ich habe ne SoundBlaster CT4830 die bezeichnung sag mir allerdings nichts weiter, weiß einer was das für ne karte ist?
J-G-W KingLuis942 „Soundkarte“
Bei Google bekommst Du 2.610 Ergebnisse bei CT4830. Das erste stimmt schon!
Olaf19 KingLuis942 „Soundkarte“
http://www.pcabx.com/product/ct4830
PC ABX Web Site
"Shedding light by means of the combustion of snake oil"
SoundBlaster Live! CT4830 PC Sound Card Samples
If you wish to download these sample files from the following hyperlinks with your web browser,
you will probably have to right-click the hyperlink text
and select the "Save Target As" (Internet Explorer)
or select the "Save Link As" (Netscape Navigator) option.
The "Reference" files on this page are identical to the like-named "Reference" files on all other PCABX web site pages.
This means that there are only 8 unique reference files that need to be downloaded from this or any other page.
You can review technical tests of this sound card by left-clicking here.
Please read this License that covers all the music files on this site
Windows users can download a program that makes comparison tests easy and scientific by left clicking here to download .
1.0 Analog 44 KHz Samples These samples were made by playing back the Reference file though the analog output of a SoundBlaster Live! and recording it through the analog input of the same sound card. Any slight level mismatches that may have been encountered were removed digitally after recording in order to eliminate audible differences due to level mismatch.
(Es folgt eine Riesen-Sammlung von Samples orchestraler Musik-Instrumente...)
Tangomann123 KingLuis942 „Soundkarte“
Müßte eine "Creative Labs" sein!!!!!
